18-Opal
April 18, 2023
Can't post due to Error: "Message cannot exceed 20,000 characters."...but I only entered 3725 chars
  • April 18, 2023
  • 2655 views
I tried updating the following document with some additional information:
Although I could edit it the website wouldn't let me save it and got the following error:
  • "Message cannot exceed 20,000 characters."
Yet, when I copied and pasted the contents into Word and count the characters I get
  • 3725 characters (including spaces)
When I look at the "source code" in HTML I get
  • 80,287 characters (including spaces)
Based on this I am thinking that it is rejecting my edits due to HTML being ridiculously verbose.  Is this intended?  Can the limit be increased?  Can you have it count text only instead of HTML code? Anything else that can be done?
It is noteworthy that I only added a few lines and it was otherwise as the post existed prior to me touching it today.
Best answer by AndrewK
Hi @LawrenceS, unfortunately you are correct, and HTML is counted towards the limit. We may be able to have this limit increased, but it isn't an issue that comes up often, so we haven't pursued that before. I will bring it up with the community team. In the meantime, there is a way to circumvent this limit. I'll message you with the details.
AndrewK
AndrewKCommunity ManagerAnswer
Community Manager
April 19, 2023
AndrewK
Community Manager
April 24, 2023
@LawrenceS just wanted to give you an update. We had the character limit raised substantially, so this shouldn't be an issue in the future.
LawrenceS18-OpalAuthor
18-Opal
April 24, 2023
Thanks again for your help with this @AndrewK!
