"Correcting" my format automatically.
Dale_Rosema
With my post at PTCooler, https://community.ptc.com/t5/PTCooler-OffTopic/2021-12-02-Friday-Humor-on-Thursday-Engineering-school-failed-me/m-p/761523#M826
It's a 10 items countdown. When I pasted the post into the body, the software decided it needed to fix my numbering on the topics:
So 9 became 11, 8 went to 12, so on and so forth. Is this a bug in the software?
Thanks, Dale
9 REPLIES 9
StephenW
(To:Dale_Rosema)
The other day, my number list changed to all 1.
olivierlp
Community Manager
(To:StephenW)
Interesting... I can't reproduce this.
I use a PC. I started a numbered list on OneNote using the numbered list feature, pasted as plain text first, then "normal" pasting.... It does not change the # formatting.
I tried elsewhere doing the same thing from a draft in an Outlook email, still fine.
1. Lorem ipsum
2. Lorem ipsum
3. Lorem ipsum
4. Lorem ipsum
5. Lorem ipsum
6. Lorem ipsum
7. Lorem ipsum
8. Lorem ipsum
9. Lorem ipsum
10. Lorem ipsum
11. Lorem ipsum
12. Lorem ipsum
13. Lorem ipsum
14. Lorem ipsum
15. Lorem ipsum
16. Lorem ipsum
  1. Lorem ipsum
  2. Lorem ipsum
  3. Lorem ipsum
  4. Lorem ipsum
  5. Lorem ipsum
  6. Lorem ipsum
  7. Lorem ipsum
  8. Lorem ipsum
  9. Lorem ipsum
  10. Lorem ipsum
  11. Lorem ipsum
  12. Lorem ipsum
  13. Lorem ipsum
  14. Lorem ipsum
  15. Lorem ipsum
  16. Lorem ipsum
then pasted as Text:
1. Lorem ipsum
2. Lorem ipsum
3. Lorem ipsum
4. Lorem ipsum
5. Lorem ipsum
6. Lorem ipsum
7. Lorem ipsum
8. Lorem ipsum
9. Lorem ipsum
10. Lorem ipsum
11. Lorem ipsum
12. Lorem ipsum
13. Lorem ipsum
14. Lorem ipsum
15. Lorem ipsum
16. Lorem ipsum
Olivier
Dale_Rosema
(To:olivierlp)
Still had the document open - does it again.
The Top 10 Things Engineering School Didn't Teach
  1. There are about 10 types of capacitors.
  2. Theory tells you how a circuit works, not why it doesn't work.
  3. Not everything works according to the specs in the databook.
  4. Anything practical you learn will be obsolete before you use it, except the complex math, which you will never use.
  5. Always try to fix the hardware with the software.
  6. Engineering is like having an 8 a.m. class and a late afternoon lab every day for the rest of your life.
  7. Overtime pay? What overtime pay?
  8. Engineers rule the world until the next revision.
  9. If you like junk food, caffeine, and all-nighters, then you should go into software.
  10. Dilbert is a documentary.
Dale_Rosema
(To:Dale_Rosema)
I just saved the doc and was going to attach it. I don't see away to do that.
olivierlp
Community Manager
(To:Dale_Rosema)
Where do you paste the list from?
Olivier
Dale_Rosema
(To:olivierlp)
A word doc. I copied the contents from a page on the internet.
AndrewK
Community Manager
(To:olivierlp)
I was able to reproduce this copying from word.
This was copied from notepad
10. Lorem ipsum
9. Lorem ipsum
8. Lorem ipsum
7. Lorem ipsum
6. Lorem ipsum
5. Lorem ipsum
This from word
  1. Lorem ipsum
  2. Lorem ipsum
  3. Lorem ipsum
  4. Lorem ipsum
  5. Lorem ipsum
  6. Lorem ipsum
It appears word ads html making this an ordered list which is fine unless you are counting down. Then it decides to renumber it for you 😀.
AndrewK
Community Manager
(To:AndrewK)
Pasting as plain text does prevent this though.
Dale_Rosema
(To:Dale_Rosema)
Or when you have subpoints - it ignores this too:
