2015 Kit of Parts CAD files
  • January 4, 2015
  • 4 replies
  • 7128 views
Will there be CAD files for the 2015 kit of parts and game pieces from PTC, or did these come from First in past years?
Thanks so much
    Best answer by sm_01
    The PTC FRC Field for Recycle Rush is now available for download @ http://www.catalogds.com/db/service?d=first&c=browse The full KOP is coming soon...
    Yes! It is still in progress and hope to have it out soon...
    The PTC FRC KOP for Recycle Rush is now available for download @ http://www.ptc.com/go/firstkop
    Or if you can't wait and have Creo v3, you can import the SolidWorks parts & assemblies from the usfirst.org website. Nice new feature PTC!
    sm_011-VisitorAnswer
    I have asked for that in the past too!!! Would save a lot of time, I/O and disk space usage.
    The am-3000 (roboRIO) part is huge (55MB). Is that expected? It takes a long time to manipulate on my older computer.
    Rande, this model comes directly from National Instruments. The best way to simplify this on your older computer is to replace it with a "box" representation. Just create an extruded box of the same size and use it as the primary component in your design. The electronics only need to be packaged in most cases, so using over simplified versions is a quick and easy way to get this done.
    Someday I'll have to record a video of the old electronics packaging demo I did as a FIRST kickoff workshop years ago. The strategy was the same, replace the heavy cRio and Jaguar models with lightweght representations to simplify the packaging process in CAD.
    -Scott
    roboRio - Does a CADD model with labeling on top surface exist?
    If you are looking to make a nice picture, a method I have used is to take a photograph of the item, crop it to exactly the outline of the surface (just to where the flat part drops off to chamfers) and then apply the image as a decal appearance to the part.
    These are some videos covering applying decals:
    https://www.youtube.com/watch?v=D_obWoUnDd8
    https://www.youtube.com/watch?v=EE6XvIeAMUQ (some audio problem, but the clicks are slow enough to follow)
    Using a program that allows the use of transparency and saving the image as a PNG file will allow the original surface color to show through. JPG files do not have transparency. There is a utility with Creo that allows conversion of an image : This post will help http://communities.ptc.com/message/236019#236019
