(-9) Invalid Host
  • May 23, 2023
  • 5318 views
Hello can somebody help me with this problem I have to finish my project but i cant due to this Warning. It is a "License Warning" and it says: "Requesting CREOPMA_SchoolSTD6... -(9) Invalid host. Run ptcstatus.bat for server status".
I get this warning everytime when I open Creo please help!!!
this message tells you that Creo cannot find network card mentioned in license file.
1.]
License file is located in hidden C:\ProgramData\PTC\Licensing directory.
You can open license file in Notepad and locate PTC_HOSTID= text. Equal sign is followed by MAC address of network card.
2.]
You can open Command prompt window and launch ipconfig /all command in it. Command output contains list of all network cards installed in your computer.
3.]
MAC address mentioned in license file must exist in ipconfig /all command output.
Thank you so much for your reply. The MAC address does exist in ipconfig/all.  Does different Networks have different MAC addresses, because this warning occurs everytime when I am using Creo not at home. I sometimes have to work on my project at school or at a coffee shop so do I have to change the MAC address from the located Network in PTC_HOSTID= ?
Again thanks for your reply and help
I checked my randomization and it is turned off. Now I am at school and I cant reach creo again. Down below I attached the ip.txt from school and the licence file is the same as above. So HostID= xxx did not changed at school it is still the same as at home.
