About manufacturing in Creo
  • March 20, 2015
  • 1411 views
I work at the University of Michigan - Flint. We use Creo Parametrics Manufacturing to run our HAAS Mill. I have problems with various things such as drilling sequences. I can make it drill however I have to add a G83 to the mix as Creo does not have this line transferred over. What issues have you had with Creo Parametrics Manufacturing?
    That sounds like a post processor problem. Have you checked the file through the NC Processor application? If the G83 canned cycle is disabled in the post processor the programme will output the drill cycle as G01 and G00 commands, instead of a G83 and a set of X Y coordinates below.
