Can't change language in Creo Parametric 7.0
Hi, i can't seem to change the language in Creo Parametric 7.0 from english to german.
I've already tried adding the "ENV=PRO_LANG=german" line in the parametric.psf even with german language selected during installation.
I've also changed the system language with a clean install but without any results.
