Creo 1.0 University Edition on iMac running Parallels v7
As a Trainer I have recently received the University Edition of Creo 1.0. Having easily run Pro Engineer WF5 on my iMac using Parallels v7, I didn't anticapte any problems when I ran Creo 1.0. Unfortunately it hasn't worked out that way. The main problem is when I extrude the 'ghosted' image does not appear. If I click to accept then it extrudes fine. Other what may be related problems are the 'remove material' icon not greying out when I move a feature backwards and forwards through a surface. Any ideas? I'm worried that it may be a Parallels related problem - but there was no issues with WF5.
Thanks in anticipation. Paul
