3-Newcomer
May 12, 2025
Creo 10 - Hiding Edges in Section View
  • May 12, 2025
  • 2 replies
  • 954 views
Is there a way to hide or turn off visible edges in section view, when rotating models around?  When turning away from the cut side, the edges of the part(s) are still visible, and this can be very annoying.  Please see example image attached.  I have already tried going through all settings and Config editor, and cant find anything relating to this.
Thank You!
AFAIK the outline of x-section is always visible. You cannot turn it off.
Community Moderator
May 19, 2025
Hi @CC_2846,
Anurag
CC_28463-NewcomerAuthor
3-Newcomer
May 19, 2025
Only one answer, and did not help me to solve my problem.  Perhaps my issue cannot be fixed, but would like someone from PTC to chime in if possible.
if you would like someone from PTC to chime in then you have to open a Case at PTC Support.
