Creo 3.0 Student Edition - Error Message stating incompatibility of Creo Parametric and Creo Direct Student Edition?
  • June 2, 2017
  • 3 replies
  • 3891 views
When I wanted to create a new part in Creo 3.0 student edition, there was an error message which says:
β€œThe file C:\Program Files\PTC\Creo 3.0\M110\Common Files\templates\direct_part_solid_inlbs_rel.prt was created with a commercial version of Creo Parametric and is not compatible with the version of Creo Direct Student Edition (for educational use only) you are running.”
How do I resolve this?
Thank you!
    Good day -
    Moving this to the Academic Community to give it the right exposure.
    create empty part.
    MH
    What do you mean? by "Create an Empty part"?
    • File > New > Part
    • uncheck Use default template option
    • click OK
    • select Empty item
    • click OK
    Was this ever resolved?
