Creo 3.0 Student Premium?
  • October 26, 2016
  • 4394 views
Hi all
I've just downloaded (for £185ish) the student premium version of Creo 3.0, but it doesn't seem to offer either the NC milling or injection moulding processes that I actually need for uni. I'm curious if it's maybe just an error I've made during installation or if it actually doesn't offer 80% of the functionality that students need?
Thanks for any help...
Calum
    Best answer by MartinHanak
    if you go to PTC Webstore and activate Key features tab, then you will see contents of the Premium license. NC manufacturing and Mold is not present.
    MH
    did you check your license file, if it contains needed modules. Please publish picture of contents of your license file.
    MH
    cwatson1-VisitorAuthor
    Thanks for the quick reply Martin
    I'm not really sure what to look for, but this is what's in the downloaded file:
    If you can point me in the right direction I'll have a look for whatever you need to know...
    For example we need the mold cavity option which is grayed out here, which is basically an entire module for uni which I can't do at home:
    Thanks again
    Calum
    1st picture ... installation media
    2nd picture ... File > New dialog box
    None of pictures contain licensing information. I guess that you received license file via email. The file is somewhere on your disc, its name is something like *license.dat.
    To see modules included in your license, you can click File > Help > System information and scroll the output (this sequence is valid for Creo 2.0). You will see something like this:
    MH
