Creo 3 rendering
  • November 6, 2014
  • 3 replies
  • 7750 views
Is anyone else experiencing problems with the rendering facilities in Creo 3?
I am finding it almost impossible to create good quality renders of wood grain and difficult to replicate renders that I have previously executed easily with Creo 2.
It was possible in Creo 2 to create an acceptable render using the default settings but now it is necessary to adjust lighting otherwise the render is much too dark. Even with lighting adjusted it is very difficult to get a good quality render of grain.
I personally am most dissapointed with what I have seen so far.
Does anyone have any more positive experiences with the rendering facility?
Roy Handley
    I am still using Creo 2 so I can give files to schools.
    Just had a quick go and had no problem opening 2.0 Academic files.
    The render seems to work the same way except the render appears in a new window. I tried changing the wood grain direction and scale on the boiler which seemed to work for the two renders below.
    I think I know what has happened. In Creo 2.0 advanced material textures wouldn't display properly when modelling with the shading with Reflections' option set for the graphics window. They do now, see the screen capture below of the modelling window..
    It seems making advanced textures work in live view may have changed the way proper render works. Is this a case of one step forward to improve 'window dressing' resulting in two steps back for core functionality?
    Is it my imagination or does draft render work much quicker in Creo 3.0?
    The larger image of the train was the modelling window without being rendered but with the "Shading With Reflections" option chosen.
    The top two windows were done with 'Render to Window' with 'Maximum' setting.
    Roy,
    Just an FYI, i'm looking into this. I hope to know something more about it later on today.
    Thank you - look forward to a possible solution
    Roy
    Roy,
    Just sent you an email directly. I'd like to do a test of this myself to get more info.
    7-Bedrock
    January 12, 2017
    Hi Guys,
    This is my first time here.. Im bhav...
    Since Creo 2 license has been expired, we had to upgrade Creo 3, Ever since we had Creo 3 it was not good as Creo 2, because when rendering in Creo 3 it's take forever to rendering and the picture quality is poor. Where as Creo 2, the picture quality was excellent and rendering were rapid. Is there a setting that i have missed on Creo 3?
    Please help
    thanks
