Creo 4 license came with Creo 5 student edition
  • October 12, 2018
  • 2 replies
  • 7252 views
Hello, I'm a university student and I installed Creo 5.0 for students, after opening there was an error message saying license file not supported for this version. Creo exits after I close the error message. I opened the license file in txt and it appears to be a Creo 4.0 license for K12. Please help
Best answer by MartinHanak
did you enter Product code BE500806EDSTUDENTEDK12 during installation ?
Did you follow instructions mentioned in http://apps.ptc.com/schools/references/install_creo5_schools_standard.pdf document ?
I face the same issue few minutes ago. Indeed I used BE500806EDSTUDENTEDK12 when installing but when I tried to open Creo Parametric it says "licence request failed for feature" (see attached)creo.JPG
Error message tells us that Creo startup command is configured to use
C:\ProgramData\PTC\Licensing\BE410708EDSTUDENTEDK12_license.dat file.
It looks like you used Creo 4.0 before you installed Cro 5.0.
Go to C:\ProgramData\PTC\Licensing directory and look for BE500806EDSTUDENTEDK12_license.dat file.
If it is not present then I suggest you to:
  • remove all files from C:\ProgramData\PTC\Licensing directory
  • uninstall all Creo 5.0 items
  • install Creo 5.0 from scratch using Product code BE500806EDSTUDENTEDK12
If it is present then I suggest you to:
  • open BE500806EDSTUDENTEDK12_license.dat file in Notepad
  • locate INCREMENT CREOPMA_??? line to get current license name
  • go to CREO_LOADPOINT\Parametric\bin directory
  • open parametric.psf file in Notepad
  • replace CREOPMA_SchoolSTD4 text with current license name
  • replace C:\ProgramData\PTC\Licensing\BE410708EDSTUDENTEDK12_license.dat path with C:\ProgramData\PTC\Licensing\BE500806EDSTUDENTEDK12_license.dat
  • save parametric.psf file
  • launch Creo
while opening creo 5.0 it is showing that license request failed for feature and license file does not support this version please help me go through itScreenshot (1).png
