Most likely, if you got the error message you had copied the code with some blank spaces.
You can try to run setup.exe again, choose reconfigure existing software and type the correct code in the simple licensing field.
If you still get the error, please hold the mouse over the Error sign and it will tell you what went wrong.
Alex
Alex
