Creo 6.0 student edition came with license key for creo 5.0
  • October 18, 2019
  • 17251 views
Hello, I'm a university student and I installed Creo 6.0 for students, after opening there was an error message saying license file not supported for this version. Creo Closes exits after I close the error message. I opened the license file in txt and it appears to be a Creo 5.0 license. Please help
Best answer by MatthiasP
I followed the steps from the pdf thoroughly, but it still doesn't work. I've made a screenshot of the error window.
Kind regards
valid Product codes for Creo 6.0 follow ...
K-12 students can use Product code BE600908EDSTUDENTEDK12
University students can use Product code BK600908EDSTUDENTEDUNI
Also read carefully:
https://apps.ptc.com/schools/references/install_creo6_schools_standard.pdf
or
https://apps.ptc.com/schools/references/install_creo6_unistudent_standard.pdf
MatthiasP1-VisitorAuthorAnswer
Kind regards
Hi  MatthiasP,
It seems to me that the Creo was licensed with an older version product code.
Solution is simple:
Run setup.exe of Creo 6.0 (from the unzipped folder) and choose Reconfigure existing software.
Use the Product code provided above for the version you need and finish the reconfiguration.
This will fix it.
Alex
