3-Newcomer
January 26, 2023
Creo 7 Student license renewal
  • January 26, 2023
  • 1882 views
I have installed Creo 7 and Creo8.
Now, when I start Creo 7 it asks for a renewal of the license. The Problem is that I can install the License for Creo7 but not the license for Creo8.
Furthermore, when I start reo7 it searches for the Creo8 license. The installation for the creo7 license worked, but when I try to install the creo8 license an error occurs.
Thanks for help.
Best answer by MartinHanak
please read following documents.
https://apps.ptc.com/schools/references/install_creo7_unistudent_standard.pdf
https://apps.ptc.com/schools/references/install_creo8_unistudent_standard.pdf
In these documents you can find Product codes. Also you can find there important note ... please go to C:\ProgramData\PTC\Licensing and delete all the older licenses
This means that you have to:
  • delete all files from C:\ProgramData\PTC\Licensing directory
  • install Creo 7.0
  • move Creo 7.0 license file from C:\ProgramData\PTC\Licensing directory to another directory
  • install Creo 8.0
  • move Creo 7.0 license file back to C:\ProgramData\PTC\Licensing directory
  • install Creo 7.0
  • install Creo 8.0
