Creo Mold Analysis Extension for Academic Use
  • October 27, 2014
  • 2 replies
  • 3312 views
Academic Support,
I have one question about Creo Mold Analysis Extension for Academic use, the module is available into PTC University Plus package?
Right now, the Module does not work like the picture show
    Hi Juan,
    It looks like there is a problem with the picture that you posted. Could you please try to send it again?
    Thanks!
    Is this part your active window? This can happen if you switch windows without using the active windows in the quick access toolbar.
    Hi, Mark
    The active windows is active, I think that the problem is the academic license with the module ? because active windows work different with CREO 3.0, automatically
    "The user interface has also been updated. You no longer need to manually activate a window when switching between open model windows. PTC Creo now automatically activates and brings forward model windows in several situations."
    This module is available to the academic license ?
