I have successfully downloaded Creo Parametric. All the icons on the toolbars appear to work but upon selecting sketch or anything the screen remains white, nothing is displayed. If I try to draw a line, the line is not visible on the screen. I have attached a print screen of what I can see.
Any help would be much appreciated,
-Sal
Salvatore,
To fix your problem, I would try the following options (in order):
What Windows OS and video adapter are you using?
Try to contact with PTC: -. Or use "Contact Support" here (you need to fill "PTC Academic Support Request Form"):
Salvatore,
Thank you very much. I tried option 3 and it worked!
