I download and installed Creo Parametric 3.0 M070. When I try to run the program, the Warning Message List appears, saying "License request failedfor feature"
The license I received by email is, BK309206EDSTUDENTUNICL
Thanks for you help.
regards,
Gerardo
your license enables you to run Creo Parametric 2.0 only, because its version is 33.0. You need to get license with version 34.0.
MH
Hi Gerardo,
I believe you have received the wrong license. Below is the installation guide of Creo 3.0 University Student Standard. Please follow the steps to install it.
http://apps.ptc.com/schools/references/install_creo3_unistudent_standard.pdf
Abdul
Thanks so much Abdul! This email solved the problem for me.
Gerardo
