I have installed creo version 10. After successfully installation of the Creo parametric . It is not running. When i start run its just open and then close without any warning. Then i also tried to install other versions & then i get the same problem.
please publish hardware specification of you computer + operating system version.
graphic card ???
Windows version ???
How do you start Creo?
please start System Information application, Save file with .nfo extension, pack the file into zip file and upload zip file.
you can also test following tip.
