Creo Quality Agent won't install
Creo quality agent fails to install at 36%. Tried many times. Made sure to run setup as admin and turned of antivirus. When I run creo parametric, it says I need to register the quality agent. I say OK and it crashes with error code 0x0...09. I know the quality agent is required for academic licensing. This is for an FTC team. Here is the install log:
Overlapped I/O operation is in progress.
