Creo common files installation not possible
LK_9838233
2-Explorer
Hello everyone!
I had following issue when trying to install the creo 7 application: The common files could not be installed because apparently the creo 7 Platform Services were not installed, althroug the were. The problem should be clear in the attached screenshot.
Here it says the requirements for the common files which are creo 7 platform services are not met. Above it says the creo 7 platform services have been installed. I would like to restart the whole installation process because I had other issues before which I solved but may have caused this one. But I used a License Key from my school and do not know wheter I'll be able to use ist again.
Thank you all in advance!
Problem solved! The license was installed and could therefore be reused
