Creo file for missing Tetrix part - W41789 - servo bracket
  • December 13, 2016
  • 2 replies
  • 2314 views
Does anyone have a Creo part file for the flat servo mounting bracket that is a part of the W41789 mounting kit. It doesn't seem to be in the KOP provided. Here's the link to the Tetrix part: TETRIX® MAX Standard Servo Mounting Kit (W41789)
Thanks for you help!
Linda
Best answer by smorris
Linda Stewart‌, hot off the Pitsco press. The attached ZIP contains Creo CAD files for the items included with W41789 - TETRIX® MAX Standard Servo Mounting Kit.
  • Servo Bracket
  • Shaft Coupler
  • D Shaft
  • Bushing
Linda, that is a new part from Pitsco. I don't remember seeing it before. I will put in a request with PTC to update their KOP with Pitsco.
smorris1-VisitorAnswer
  • Servo Bracket
  • Shaft Coupler
  • D Shaft
  • Bushing
lstewart1-VisitorAuthor
Awesome! Thank you Pitsco and Scott!
