Creo is losing files from sub catalogs.
  • August 14, 2017
  • 2322 views
When I am selecting working directory, creo is losing files from sub catalogs. Is there any solution this problem?
please provide more details (use text and pictures) to explain your problem.
My problem is very simply. I created working directory in creo. Then a created assembly. In my working directory I created sub catalogs. I created sub catalogs because I want to have tidiness in the directory. I sort files on few groups. But problem is when I open my assembly, creo losed files which are in sub-catalogs.
I have one more question. Is there possibility that creo will remeber my working directory in new sesion. Is there some option to create file with name of projekt like is there in Inventor for example.
1.] working directory setting
Edit properties of windows shortcut and put the appropriate path into Start In field.
Edit config.pro file - add following option
file_open_default_folder   working_directory
2.] assembly and its components in subdirectories
If the assembly file is located in C:\myfiles directory
and its components in C:\myfiles\mycomponents directory,
then you have to add following option into config.pro file
search_path   C:\myfiles\mycomponents
