Dimensioning
  • June 3, 2012
  • 1195 views
I would like to know how to dimension from two point on wildfire 5 and preferably be able to change it.
Thanks.
    Hi Angus,
    To place a dimension between two points, you will need to have the Normal dimension tool selected. With the Normal dimension tool selected, click the two points which you want to dimension, and middle click to place the dimension.
    For more help on sketching and dimensions, check out the Primer. This is a great place to start if you are learning your way around Pro/ENGINEER.
    Curtis Siebenaller
