Drive Motor Calculation.xmcd
  • January 23, 2011
  • 2 replies
  • 2617 views
This Mathcad file calculates the drive train motor (for toughbox and sprocket gearing using a CIM motor).
Illustrations and explenations in the file
    Hi Itzik,
    I finally got a chance to check out your motor calculation in Mathcad.  This is fantastic!
    This is very similar to what I am hoping to get put together for teams locally.  My goal is to have a library available for common calculations that include explanations.
    I think it would be a great way to introduce students to the statics and dynamics of their robots and then let them compare to empirical results.
    I'll share with the community as I progress.
    Also...we'll be using Windchill to share data and allow students to edit documents by check-in/check-out procedures.
    Great Job Itzik!
    It is terrific to see Mathcad used in this way. You have made use of (and demonstrated) Mathcad's key features for engineering calculations:
    • Standard Math Notation & Unit Handling Capabilities for Engineering Calculations
    • Text capabilities to provided documentation of the purpose and execution of the worksheet
    • Image handling to provide a graphic illustrating the calculation
    Well done!
