Error Uploading Documents [Windchill 10.0]
I'm having some trouble uploading documents to Windchill 10.0, using the RWDC portal at https://rwdc.ptc.com.
We have found the current capabilities within the "Meetings" section of the Navigator in Windchill to be lacking, so I decided to create a folder for all meeting notes in the "Folders" section of the Navigator.
Fig 1:
(Note you can click on the images to expand them if they do not display fully within the thread dimensions. Please notify me if you cannot fully see the images.)
Within the Meeting Notes folder is notes from two previous meetings, which I had uploaded previously with no problems.
Fig 2:
When I attempt to create a new document using the "New Document" button the dialog appears and I filled it out (what is believe is) correctly.
Fig 3:
I assume the "Set Attachments" page is not needed as I have only one file to upload. Therefore I click "Finish" in hopes that it will create the document space and upload the file to the Windchill server; however it throws what looks like a Java error.
Fig 4:
I have tried using no number sign and/or spaces in the Name section of the Attributes area, but to no avail. Any idea what might be going on here? This problem is severely impacting our ability to collaborate and share important documents and notes within Windchill.
Thanks in advance!
- Ben
