How to use Blend or Variable Section Sweep to create an extruded part?
  • February 3, 2024
  • 6909 views
Starting from the attached box, having dimensions 7,4,3 mm, I want to use either Blend, Variable Section Sweep with two trajectories, or Extrude up to a datum plane created by specifying three points, to create the attached extruded  part, with the dimensions specified in the image.
After going over quite a few tutorials, I still have no idea how to approach this question. Is there any chance you will be able to guide me through the process using each one of the methods I mentioned? (i.e. Blend / Variable Section Sweep / Extrude)
Thank you!
Best answer by MartinHanak
please watch uploaded video.
Thank you so much Martin! Is there any chance you'll be able to upload the video showing the first two sketches (or maybe look at the attached video)? My problem is that I am not able to specify the length of one of the lines to be "6" without creating a line there (and as you can see in the attached video, if I do create a line there, I have a very ugly additional line that doesn't appear in your video).
I see. The problem is that Creo doesn't let me choose the line endpoint and create another dimension out of it and the other surface.
I will give it another try anyway.
Thank you
