Limited Windchill 10 Access via Creo Parametric 1.0 M020
  • January 28, 2012
  • 2 replies
  • 10285 views
Hello all FIRST folks!
Hope everyone has been have a challenging yet productive season. I must admitted the we the 167 Buchanan Bird Brains have have many obstacle to overcome, yet we are still having fun and learning lots! You can read more here: Evan G's Blogtime Array.
In any case, our team has been having difficulties establishing a solid connection to the Windchill 10 FIRST Robotics server via Creo Parametric. Logging into the the server via Internet browser works perfectly, but when working through Creo, strange things begin to happen. Sometimes we can connect easily and things work beautifully. Other times we can connect, then an error message saying that the server is unavailable pops up and ruins our work session. In one extreme, a student won't beabel to connect at all!
I have found that usually the best temporarily solution is to delete the .wf server cache folder located in (for Windows 7) [Install root directory, usually C]:\Users\[Account Name]\AppData\Roaming\PTC\ProENGINEER\Wildfire or (for Windows XP) [Root directory]:\Documents and Settings\[Account Name]\Application Data\PTC\ProENGINEER\Wildfire. (If not those exactly, something similar.) This forces one to register the server again for a new session.
My question is: Have other teams been having similar issues and/or what is the best way to resolve this problem?
Thanks in advance for your help!
Evan Giarta
Chief Executive Officer, 2011 - 2012
Director of CAD and Design, 2010 - 2011
Buchanan Bird Brains FIRST® Robotics Team 1671
http://www.team1671.com/
    I would like to reiterate Evan's request for feedback from other teams.
    This is just to add to Evan's request for feedback from other teams.
    I'm a mentor with FIRST Team 1671 as well as an administrator of PTC products with Pelco by Schneider Electric.
    We are still looking at tracking down the server problem. It appears to be a bandwidth issue. Multiple students working in the same project from the same location appears to be the primary problem. While on occassion, we do see decent performance, it appears that more than one student checking/uploading CAD data at the same time is creating a bottleneck.
    From my experience, it appears that Creo 1 is erroring out much more often than any previous release of Pro/E with Windchill. That being said, we saw similar problems with Creo 1 and Windchill 9.1, which was said not to work at all.
    One thing that we've recently tried was dm_http_compression_level 6. Supposedly this will conserve bandwidth on upload to the server (in Germany of all places!). So far it appears to help to some extent, yet performance is still well below what I would expect.
    Josh
    Team 175 having similar issues with Creo/Elements 5 but with just 1 user uploading. Even occurs from my Corporate network -- SOAP internal error. Am in process of installing Creo 1 on all of our machines because students say its easier. Now see that may have even worse performance with Creo 1 and Windchill 1.
    Did not realize that server is overseas.Cosmin is doing a great job but couldn't PTC supply server state-side? Seems like we are showing the kids the same issues I see trying to work with and exchange data with outsource facilities outside the USA.
    I also have to now consider that I connect to Germany via my Corporate WAN!
    Posted issue to support.
    February 2, 2012
    Unfortunately Windchill 10.0 is only certified to work with Creo Elements/Pro date code M090 or higher. Teams have two choices in this situation, upgrade to Creo Elements/Pro to M090 or move to Creo Parametric 1.0.
    To check the date code of your Creo Elements/Pro installation, click Help> About Creo Elements/Pro.
    I hope this clears up any confusion. To upgrade, please email -.
    Adam
    Arrgh! Make it stop!!
    Concur!!!!
    Finished current download from ..../go/first of Creo Elements/Pro. GUESS WHAT?! ITS STILL M080!!!!!
    PLLLLLLLEEEEEEAAAASSSSEE PTC MAKE THINGS RIGHT AND OPERATIONAL.
    I spend hours with these kids and now I have to do the installs all over again and still no guarentee!!!
    We use "ancient" ProIntralink 3.4 with Wildfire 3.0 at my company to design Space hardware - been customer driven. Been pushing my management that we need to get with the times and move to Windchill and WF4 or WF5 but based on my experiences so far, adult Engineers, Designers and Drafters would be wringing my neck!
