Im planning to put my hands on Pro-program and looking for some tutorials on the same.
Could any one please share the tutorials on the Pro program if you have it.
Also is there any pre-requisites for getting started with it.
Thanks in advance.
Hi Vineeth,
There is a free tutorial on PTC University Learning Exchange on the topic:
http://learningexchange.ptc.com/tutorial/141/pro-program-primer
You can also consult the online help. Here is the link into the top level on Pro/PROGRAM. At this link, you will see the other options on the left:
You might also be interested is in the Editing a Design section, which provides usage and syntax:
Hope this helps!
Bettina
Thanks for the reply...Let me go through it see how i will be fitting in to it
Apologies for late reply as I was stuck with some other priority stuffs ![]()
