Loop generation
  • January 14, 2015
  • 4577 views
Hi
I have a matrix. How to generate a loop to read only one number in this matrix every time? I have to read one number each time and make some mathmatical operations and then go to the next number.
Can you help me with this?
Best regards
Waleed
    Best answer by RichardJ
    "Help", "Tutorials".
    Your description is too vague for me to be able to give you any advice. You need to post a worksheet showing exactly what it is you wish to do.
    You would be better off posting questions about Mathcad in the Mathcad forums.
    wkhalid1-VisitorAuthor
    Thanks for your reply, see attached photo!
    How did you define the stress? There are two columns in s matrix!
    There is nothing in either the image or the worksheet you posted that indicates that the second column has any use. I implemented what you asked for, and that uses only the first column.
    How did you make a relation between a(stress) and m(stress), and first column in s matrix?
    They are functions. I passed the first column of the s matrix to them as arguments.
