Not letting me export as stl.
  • July 8, 2015
  • 2 replies
  • 14608 views
Hi Foks
when trying to export this design as stl. its coming up 'Unable to triangulate highlighted surfsce. Aborting output'
now this part has just been extruded and shelled, so what am I doing wrong?
any help appreciated
Jeremy
    Best answer by tbrotherhood
    Extrude 3 is causing the problem, investigating...
    The sketch for extrude 3 was the problem.  I found this by moving the Insert Here flag up to below the first feature, regenerating and trying to create an STL repeat for each feature until the STL creation failed.  Extrude 3 was the culprit.  I tried altering the way the extrude was created, no luck.  I moved the datum away from the model to simplify the extrude to a single direction up to the outer surface but still no joy. Next stop was the sketch.  I moved some of the shapes apart in case the gaps were too small for the triangles, still no joy.  I then noticed the inner arcs on each shape were very close and in some cases touching the round on the large hole. Drawing a slightly larger circle and trimming all the shapes back to it sorted the problem.
    Phew!  Now to bed....zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
    Jeremy,
    The usual cause is a model made up of surfaces i.e. no solid material.
    Another cause is ambiguous geometry.  I created a mobius strip as one part and it refused to save STL probably because it is a single surface shape.  I split it into two and both parts saved OK as STL files.
    Tim
    Just a thought, did you set the facet size to smallest possible?  type 0 (zero) in the Chord Height  field.
    Hi Tim
    yep tried that, it;'s strange because all it is is a circle extruded, shelled and the all the exterior parts added, only the one side is highlighted but it's exactly the same as the other!!!!!
    hmmmm.
    hi Tim
    ok daft question time
    how do I attach file?
    Thanks Tim
    Just to let you know, this is another project we are working on, 'Birdhouses'
    really appreciate your help on this, now I know what to look out for
    Thanks again
    Jeremy
    I love a challenge and very happy to help.
