PTC Creo 6.0 Student edition renewal
  • November 10, 2020
  • 5 replies
  • 15542 views
Hi!
I have the same problem of Mr. Pixner (‎10-28-2020). My license for Creo Student 6.0 is expiring in a few days. Whenever I try to renew it, it says that my account is not verified.
I followed the indications of Mr. Alex_Cazacu but, even if I renew the password, the problem is always the same.
What could be the problem?
Kind regards,
Jacopo Magnani
cliente non verificato = Not verified customer
@Alex_Cazacu
Are you licensing Free Creo 6.0 Student edition? If so, please send me a private message with your email and I'll send you a license for 70-C9-4E-8B-17-F7 Host ID.
Alex
Sorry, I think I have the same question to ask you, what measures should I take next?
The current modeling is halfway through and the file cannot be opened because the student version expires today. I will graduate in June this year. Can I continue to use it? Thank you!
I assume you tried the license renewal from the setup.exe of your installation folder. If not, then run the setup program as if you were installing the prohram, but instead on the PTC Installation Assistant screen just choose "Setup license". Accept and acknowledge the agreements, and in the License Identification use Simple License Entry. In the blank field type in your product code and click Install Licensing. In the popup enter your username and password to verify credibility. That should solve your issues. I have also had some issues with Licensing. I tried several times, and succeeded.
3-Newcomer
May 22, 2021
Hello dradakovic, where can I the installation folder? Is this it? Notice that I have my Creo 6 Student Version installed in a G drive, an external SSD. I made my own Program Files folder and installed Creo there. Thus, there is no "PTC" folder. There is just a "Creo" folder and a "Creo 6.0.2.0" folder. I open the Creosvcs_64 file and the bottom picture appears. I clicked Repair but it took a while and didn't do anything.
I renewed it just now. Everything works fine.
I had the same problem, and this is how I renewed my student license by following the Relicense Guide (ATTACHED).
Hopefully this works for others.
Search in this file path (Note that the path may not be exactly the same):
C:\Program Files\PTC\Creo 8.0.0.0\Parametric\bin
For this file:
reconfigure.exe
Click on the file once, then right click and Run as Administrator.
If prompted, allow the app to make changes to your device.
Once you see this Introduction page, click next to enter the Licenses Page
On the licenses page, open the Node Locked Licenses drop-down and enter this value: BK800908EDSTUDENTEDUNI
You will then be asked to enter your username and password, and it will install the new license.
Click through everything from there until you are finished and open Creo to test that it will allow you to use it.
Thank you. It works.
