Pro/E 4 and 5 installation hangs right after starting setup
  • July 8, 2010
  • 2 replies
  • 8088 views
I've been trying to install schools edition of Pro/E 5 64bit and Pro/E 4 for windows 7 64bit. The installation hangs as shown in the attachment. I've tried to run the setup as administrator, with/without windows recommended settings and antivirus software turned on/off but the outcome is the same. Can you please help me with this issue.
Thanks you in advance.
regards,
Tero Oikkonen
    Hi Tero,
    I was wondering if you are on the Windows 7 64-bit Home Edition? We're having the same problem on that OS.
    did you download it from the web?
    Yep
    i beleive this is the issue...you need to reinstall it from an original CD/DVD
    BTW WF 4.0 does not support 64 bits systems....
