Problem installing Creo 3.0 Academic version
  • November 7, 2016
  • 2 replies
  • 5807 views
I have been trying to istall CReo 3.0, but I haven't been able to do it. The instalation always get's stuck where in the Aplication Selection part. There is a meesage that sasy please wait while we retrieve your license and it gever goes beyond that. Thank you for your helpUntitled.png
    please describe step by step, what exactly you did.
    For example:
    • went to PTC web page ... publish its URL
    • downloaded installation media ... which one ?
    • unzipped downloaded zip file
    • run setup.exe
    • and so on ...
    Is your computer connected to Internet ?
    MH
    In addition, when I execute setup.exe (instead of setup-school.exe) I get an error message like this:
    Your problem can be related to network card MAC address. Maybe installation is not able to get your network card MAC address.
    I can check network card status for you, if you publish contents of ip.txt file created by following command entered in DOS prompt window.
    ipconfig  /all  > ip.txt
    Also check what files are saved in C:\ProgramData\PTC\Licensing directory.
    MH
    8-Gravel
    November 11, 2016
    Hi PTC,
    Thanks for supporting us! But we got problem with installation.
    Bug report here...M070 cannot install, first thing is when i put
    BH400407EDSTUDENTEDK12, error;
    BK400407EDSTUDENTEDK12, error;
    BK390206EDSTUDENTUNICL, error,
    BK400407EDSTUDENTUNICL, error;
    BH400407EDSTUDENTUNICL, error - this one gives me a license email.
    and i manually load the license file, successed.
    then during installation, most of processing bar just show red, and crashed in 10-15 second,
    Thumbnail Viewer installed success
    Creo View Express installed success
    attach the pim_installmgr.log here
    https://goo.gl/4GU66z
    attach the traceback.log here
    https://goo.gl/JS3VyU
    computer: Windows 10 Enterprise, Build 10240, 32GB memory, i7-5960x, install on c:/, setup file in c:/, setup.exe is runned as admin.
    Before was fine on this computer, i had creo before, with setup.exe, not the one with school-tab, with the serial number BH400407EDSTUDENTEDK12, -
    Please take a look, thanks! It's not just me, our mentor also has the same problem, he's on windows 7, i manually load the license from email in, installation process did not crash.
    Gary Chen
    FRC Team 4001
    8-Gravel
    November 11, 2016
    last time success install with M070 is September with the latest version i download from website, not quite sure if it's M060 or M070.
