Problem isntalling creo elements student edition
  • December 2, 2011
  • 7144 views
I've just purchased and downloaded creo 5.0 student edition.
The downloaded file for win/64 was only 191MB. After unzipping and running install nothing happens!!! -no error codes, no student edition screen.
anyone have an idea (I'm running win7 64)
thanks
    Julian,
    Sorry you are having this problem. Try downloading the entire installation DVD at http://apps.ptc.com/schools/Creo_ElementsPro_Student_DVD.zip. This image will support both 32 and 64bit.
    This is a large download, approximately 3.6GB so unless you have a very fast connection, I would suggest you use a download manager such as Free Download Manager, this will allow you to stop and restart the download if necessary.
    Adam
    I have downloaded the files from the link now...
    I have tried running the setup file directly from the folder and also to mount it as an image on a virtual drive first. The only thing that happens is that it loads for a few seconds and then nothing!
    I have the same problem... On my laptop it is running without any problem 😞
