Hello Everyone,
I have a problem of sweeping. When I choose the option 'solid', the option material removal is activated by default and I had no way to change that. I use Creo parametric 6.0 for students.
Could you help me please?
Are you in a part or an assembly? If you are in an assembly, you cannot add material in Creo.
@JK_95.25 wrote:
Hello Everyone,
please explain what are you doing.
Do simple test ... create new part and start Sweep feature creation.
it worked in the part. Thanks
i'm in an assembly. Ok i see.
