Problem uploading reference images to PTC Creo 2.0
  • August 27, 2014
  • 4274 views
Hello, I would like to know how to properlyy upload any images to creo.
I tried to upload the image attached to Creo but for some reason, it ALWAYS fails to load.
Is there some kind of restriction I am unaware of? Do I need to change the file format?
Jason
    To be more specific, my method of uploading is
    View > Model Display > Images > Add
    Then you will have to manually browse the computer to add the image in to the datum plane selected.
    After clicking Add, the next step is selecting the datum plane you want the image to be placed on.
    Once the datum plane is selected, then you browse to and select the jpg image.
    It sounds like you may have a problem with your graphics drivers. Try the attached image which loads fine on my computer.
    If this doesn't work, submit a tech support ticket to sort out your graphics drivers.
    http://support.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482
