Problem with holes and checkmark
I am using Creo 2.0 Parametric for building an FTC robot. I have already designed a wheel but when I put in the center axle hole the check mark is grey and won't let me apply the changes. Any suggestions?
When placing a hole at the center of another round object, I like to reference the axis of the existing round object and the plane where the hole starts. Define depth as needed and you should be good-to-go.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
