Problem with importing automated mathcad files into creo
  • January 4, 2012
  • 3 replies
  • 11038 views
My team is struggling with Mathcad and Creo. We're following the tutorial but can't seem to get this sorted out.
We're using the Mathcad worksheets provided and have tried it seperately on two different computers to make sure that we're not messing anything up.
When we save the the wing_def worksheet, there should be an output of saved data of both the root and tip points. We're only getting the root file and not the tip so we're hitting a major roadblock there.
Additionally, when we tried it on the second computer on the wing_optimization worksheet there wasn't for the tip chord. It's missing from the end of the worksheet.
I will try to take a few screenshots this afternoon to include with this post that can better elaborate on our difficulties. I think the major issue is that the files that are supposed to be automated from the Mathcad worksheets aren't appearing. Maybe they're not supposed to and I'm just missing something major, but I'm not sure where to head at this point.
    Please attach your Mathcad worksheet. Also, see my comment here: http://communities.ptc.com/message/172676#172676
    I tried again to follow the tutorial this morning and these are the files. There still seems to be no output of the the root and tip profiles.
    Thank you for your help. I went to make sure that no folders were hidden, but I already had all the hidden folders shown. I attached a screenshot, but the file is still not showing up.
    This is a screenshot of the folder when I try to bring it into Creo.
    18-Opal
    January 13, 2012
    Hi Melanie,
    From the screen shot I see you are running Windows XP. The protk.dat file that you need to point to will be in the following folder:
    c:\documents & Settings\all users\appdata\MentorGraphics\FloEFD Pro 10\Wildfire 5.0\protk.dat
    or
    c:\documents & Settings\all users\appdata\MentorGraphics\FloEFD Pro 10\protk.dat
    You should be able to navigate to this from the Microsoft Explorer window to confirm it exists.
    mark
    Alright thanks Mark! I found it!
    Except now when I openned up Creo it comes up with an error. I included a screenshot of the error. I think you're actually on Teamviewer right now with one of my teammates.
