Problems Generating BOM Using Creo Parametric
I've recently been trying trying to price out new drive train options (the new COTS parts released by Vex Robotics).
If it's relevant, my process for these files is typically to download the .step file from the VexPro website, then generate an assembly. After I've generated the assembly, I go in and assign weights, colors, etc. to all the parts, as well as reassembling the assembly in order to make sure the constraints are all right.
My problem is that after I've gone through this process, I cannot generate a BOM for the assembly. When I try to do so, Creo throws a "Cannot open output file" error. I really don't know why this would be so, as I've successfully generated BOMs in Creo parametric before.
Any suggestions for what the problem is and how I can fix it?
