try following ...
1.] check the contents of C:\ProgramData\PTC\Licensing directory, installer puts license file into it
Note: If you are note able to verify validity of license file, please zip it and upload zip file
2.] maybe your problem is related to some network card
Please open DOS propmt window, run following command and upload ip.txt file
ipconfig /all > ip.txt
could you elaborate it more? I tried installing creo 4.0 but its not working too
what should I elaborate more ?
To install Creo 4.0 try following
http://apps.ptc.com/schools/references/install_creo4_schools_standard.pdf
-OR-
http://apps.ptc.com/schools/references/install_creo4_unistudent_standard.pdf
K-12 students can use Product code BE410708EDSTUDENTEDK12
University students can use Product code BK410705EDSTUDENTUNICL
