Ptc creo 3.0 not running
  • January 22, 2019
  • 3132 views
I have installed ptc creo 3.0 but after installation the programmes doesn't run at all. Can anyone solve this problem
try following ...
this process is not working, The problem is not only parametric but every
program of the creo is not running
what should I elaborate more ?
To install Creo 4.0 try following
http://apps.ptc.com/schools/references/install_creo4_schools_standard.pdf
-OR-
http://apps.ptc.com/schools/references/install_creo4_unistudent_standard.pdf
K-12       students can use Product code BE410708EDSTUDENTEDK12
University students can use Product code BK410705EDSTUDENTUNICL
