Ptc creo 3.0 not running
Ananderanki
2-Explorer
I have installed ptc creo 3.0 but after installation the programmes doesn't run at all. Can anyone solve this problem
6 REPLIES 6
try following ...
Martin Hanák
this process is not working, The problem is not only parametric but every
program of the creo is not running
1.] check the contents of C:\ProgramData\PTC\Licensing directory, installer puts license file into it
Note: If you are note able to verify validity of license file, please zip it and upload zip file
2.] maybe your problem is related to some network card
Please open DOS propmt window, run following command and upload ip.txt file
ipconfig  /all  > ip.txt
Martin Hanák
could you elaborate it more? I tried installing creo 4.0 but its not working too
what should I elaborate more ?
To install Creo 4.0 try following
http://apps.ptc.com/schools/references/install_creo4_schools_standard.pdf
-OR-
http://apps.ptc.com/schools/references/install_creo4_unistudent_standard.pdf
K-12       students can use Product code BE410708EDSTUDENTEDK12
University students can use Product code BK410705EDSTUDENTUNICL
Martin Hanák
I installed as you told but its not working
