Run Creo 2.0
  • March 24, 2014
  • 1004 views
I'm problem with creo 2.0 i've installed all files,but when I open Creo Parametric the code error that I find is 0x060000c0. I've installed the new version of Quality Agent but the problem still live!
Best answer by MarkCheli
Hi Fabio,
Have you tried downloading and running the below file?
http://apps.ptc.com/schools/references/creo2_qualityagent_fix.exe
That should sovle the problem for you. However, if it does not please let me know and we will pursue other options.
Thanks!
MarkCheli5-Regular MemberAnswer
Hi Fabio,
Thanks!
