Section View Problem
jdaily
2-Explorer
In my assembly drawing the section view wasn't working. It was working prior to inserting some additional parts in the assembly. I found the part that was causing the issue. When the part wasn't in the assembly the section view came back. What can I do to find out why this part is causing section view failure.
MartinHanak
(To:jdaily)
you can upload your assembly into this discussion. I can investigate it.
Martin Hanák
