URGENT: Removing "Used density" in the Model Properties
I did a mass properties calculation with assigned material. When I was finished I removed the material assiged but the density under "Mass Properties" was still filled in. I need to remove all material data on my part before I can check it in do to company standards.
However, I cannot enter the value 0 into the density dialog box.
If anyone can help me with this problem I would be very grateful.
/Emma
