What am I doing wrong in creating a belt
  • October 9, 2014
  • 3 replies
  • 1788 views
I have created a belt and turned into a part. And then was adding a sweep. But it doesn't seem to around the wheels. They cut in. What I am doing wrong
    Best answer by MarkCheli
    Hi Kyle,
    Got it! it looks like it was because you did the sweep as part of the assembly and not as the part. By default, doing this will remove geometry not add it. To fix this I just updated prt0002 to have the sweep feature and then I deleted it from the assembly. Attached are the files.
    Please let me know if you have any other questions!
    Have you looked at the videos on PTC Learning Exchange for Belts? As Steve mentioned, a picture of the problem would help out a lot.
    MarkCheli5-Regular MemberAnswer
    Hi Kyle,
    KyleHoyt1-VisitorAuthor
    Thank you - I was able to create one myself.
