Windchill & ThingWorx login using one Corporate LDAP ?
  • February 11, 2016
  • 2047 views
Folks,
Disclaimer : I don't yet have an installed PTC Navigate instance, so this is coming out of imagination.
As I read from PTC Navigate User's Manual, we are required to setup separate instances for Windchill Server & ThingWorx.
I was wondering if both can connect to same Corporate LDAP being used across a company.
Also, can we set different roles for same Corporate LDAP user, in Windchill & ThingWorx resp. ?
~SiD
Best answer by ibanham
If Navigate is using the ThingWorx Windchill Extension, you normally configure this so that ThingWorx uses the Windchill LDAP to perform authentication.
See section around p29 of http://support.ptc.com/WCMS/files/164699/en/WCTWXExtension.pdf for details.
ibanham1-VisitorAnswer
Thanks for your answer & attached document.
I hope to have an instance early next week where I can try out this configuration.
~SiD
