configuration editor problem
  • November 30, 2020
  • 977 views
I changed my dimensions and file locations in configuration settings  if I close and reopen the software the configurations are reset how to save the configurations given to the software
config.pro file mentioned on the picture is default Creo configuration file. I do not know how did you modify its options and where did you save modified file.
