i am having someissues with manufacturing, can anyone help me?
  • August 1, 2016
  • 3 replies
  • 9687 views
In Creo 3.0 when I attempt to open a new manufacturing nc assembly it doesn't open and and Nothing happens.
    Best answer by MartinHanak
    Creo window title reports that you are using Student Edition. Therefore you cannot create/open manufacturing nc assembly.
    MH
    It propably says in the message log that you are missing a licence for the NC module.
    jakers1-VisitorAuthor
    So here are some screenshots I took, it doesn't say anything in the dialog box. After I click OK, it simply does nothing, and the new box disappears.
    That looks like some vanilla setup.
    Click with RMB to the bottom message area and choose Message Log from the pop-up menu.
    if you are using Student license then you cannot create/open manufacturing nc assembly, because the license does not contain manufacturing modules.
    MH
    So I am in a crunch, and I really do need to use the manufacturing setting, is there any way I can get it. I am a college student, if that helps.
    maybe you can do your work in university lab ? Or you can contact some person - CAD administrator and ask him for a help.
    MH
    Hi
    I have also access just from uni but it works here.
    Better contact your IT technician. It works fine (manufacturing) by me despite occasional crashes.
    It is maybe dependent on your uni licensing.
